Gas Tank Float Repar
mwfameli
My 2000 15ft Scout Sportfisher gas gauge shows empty all the time espite it benig full of gas. I have had all of the wiring checked and performed other basic troubleshooting. <br /><br />I believe that the problem is with the internal fuel tank float.<br /><br />How do I get to it to either replace it or repair it?<br /><br />Thank you in advance.<br />-MWF
D
DJ
Guest
Re: Gas Tank Float Repar
MWF,<br /><br />I assume the tank is in the floor? If so, there should be more than one deck plate covering various outlets on the tank (fill, sender, vent.)<br /><br />Find the plate that is covering the sender. Remove it. The sender plate comes out of the tank with several screws.
