Gas Tank info for 1966 Evinrude Sportmans 150
Avantibob
Good morning. I just cleaned out the gas tank on my recently purchased 1966 Evinrude Sportsman 150 (with a GM V6 engine). I was hoping there would be markings on the tank indicating the size/capacity of it. Does anyone know the capacity of this gas tank (this is the original gas tank that came with the boat).
​Last question - what is the type and weight of the engine oil I should run with this engine. I'm guessing 30wt is what should be used (the engine only has 78 hours on it). I purchased this boat from an estate and could not get any additional info on it.
Thanks in advance!
​Bob Weir
Before you launch this boat you will need to install a new waterpump impeller in the outdrive.------If it has sat for many years the impeller will be cracked from age.------New oil in the electric shift lower unit should be TYPE-C for electric shift.------Upper gear box may well ne the weak point of this system and change the oil there too.
boobie
Use 30 wt oil for the motor. See if you can find a factory service manual for it.
GA_Boater
Welcome to iBoats.
Boobie & racerone got you on the mechanical side.
For the tank - (Length, inches X Width, inches X Height, inches) / 231 = Gallons. So you are calculating the volume in cubic inches and dividing by the number of cubic inches in a gallon.
boobie
So GA are you saying there are 231 cubic inches in 1 gallon of liquid ??
clemsonfor
I'd run 15w40 or 10w30 in it if it were me so oil would flow better on cold starts
