Gas Tank on 1994 Robalo 1820
Robalo
I was wondering what size tank is on my 1994 Robalo 1820? I was out on the water and the guage showed a lil under 1/4 and I went to fill the tank it took 39 gallons. I dont have the specs on this boat and would like to take it offshore it has a 150 merc blackmax. What kind of milege should I be getting from this 1993 150hp merc?<br /><br />Thank for all your help.....
JB
Re: Gas Tank on 1994 Robalo 1820
Moving to Boats.
Solittle
Unless someone jumps in on this best call Robalo. Before you call check for an access hole to the tank itself with a round cover ( mine is about 6"). Many/most put a data plate on top of the tank near the hole which should also be near the sending unit.
Robalo
I have allready checked the access hole and no plate. Thanks
Capt Charlie
Robalo,<br />I've got a 1996 Robalo 1820. My gas tank is 55 gallons.
