gas tank vent..
drkilldrmz
Hello all..<br /> Just a quick question at the risk of sounding reeealy dumb :) I have an older johnson 6 horse that runs great seemingly, but my question is how does the gas tank vent? It stalled out on me last week, and the cap has 3 positions.. tight, loose, and off. Does the cap need to be loose to vent?.. if so, that would explain the stalling. Tried again today, and she fired right up. thanx
S.T. Marine
Re: gas tank vent..
Should have a little screw on the top you loosen. If the tank is not vented the motor will keep stalling
drkilldrmz
Re: gas tank vent..
nope no screw on top.. Its a seperate tank, not on the motor if thats what you meant.. It just loosens, tightens , or closes.. what does everyone else with this tank do?.. thanx
bobingardner
Re: gas tank vent..
The screw for my tank is in the middle of the gauge. Have you tried that?
roscoe
Re: gas tank vent..
It depends how old your motor is.<br /><br />If it is from mid sixties or older, it will have a double hose fuel line. The engine pumps air into the tank to pressurize it, forcing the gas up to the engine. A tank like this has no vent, and must remain closed so the pressure can build up.<br /><br />If you have one of these tanks, do not get rid of it, no one makes them anymore.
digimortal777
Re: gas tank vent..
whats hes sayin is very simple , his tank has no vent<br /><br />you have to open the cap a little to vent it , my tank for my 82 johnson 15 is the same
drkilldrmz
Re: gas tank vent..
The line from tank to motor has only one hose, and the bulb. It is from 1968, and the tank is in great shape. I believe my brother has a similar tank, but much, much newer. He doesn't vent his, but the way the motor stalled on me, and smelled "gassy" I thought it was an easy answer. so.. anytone with a tank that has these 3 positions should open to the loose position?.. or not..?.. thanx
