Gas Tank Ventilation
Outboard_Newbie
I have a 1979 Evinrude 25 hp outboard. Runs great, but the plastic gas tank compresses when I run it for an hour or more. I have the ventilation tightened all the way and periodically release it to relieve some of the pressure. Should I have the ventilation opened or closed on the gas tank?tank?
wilde1j
Re: Gas Tank Ventilation
Vent must be ALWAYS open when motor is running, or as you state, the tank will collapse. Closed is OK when done for the day.
Outboard_Newbie
WildeOne I didn't know if there would be a problem with releasing the pressure in the line. Your response makes sense. Thanks!
Bob_VT
Even the "stock" metal tanks are slightly vented otherwise they would collapse :eek: <br /><br />Just partially open the vent valve a little while your running.<br /><br />Bob
