gasket for bell houseing
dondi
1985 thundercraft 140 hp merc i o. if i open the bell houseing to check for water or check the bearing is there a seal or gasket i must replace afterward?like to have everything ready to go if i do
Bt Doctur
Re: gasket for bell houseing
the outdrive mounting kit,should never reuse a gasket.
Don S
Never reuse the gaskets and rings between the drive and bellhousing.
Here is the kit you need.
attachment.php
