Gasket maker and water pump change. Problem or not?
herbertk1
Hi, I am very new to outboards and I think I made my first (of many) errors. I just replaced the water pump on a 1999 Evinrude Ficht 200 hp outboard. I inadvertently used permatex water pump gasket MAKER rather than Gasket Sealing Compound, which is called for in the instructions. I used the gasket that was included in the kit, but instead of a thin coat of gasket sealing COMPOUND, I used a thin coat of Permatex Water pump Gasket MAKER. How bad of a screw up is this? The lower end is not on the engine yet, so I can try and repair my error. Or will the water pump gasket MAKER be ok?
Thank you
Faztbullet
It will be fine other than when servicing again as gasket will be a bear to clean off...
