gasket maker for aluminum case.
Nuaticocat
I just bought a 2002 merc 75 4 stroke that was in a box. It had a ruined con rod bearing and 1 slightly scored cylinder, and was missing 1 valve keeper half? It has been an interesting journey. The atttention to detail required to build this motor is daunting. I have worked through most problems, but I am concerned about what sealer to use on the block halves. I am planning on using black max hi temp. Is this safe for aluminum? Anybody know what the correct choice is?
Any advice on this motor would help.
thanks
M
Maxz695
Guest
Re: gasket maker for aluminum case.
<edit> Deleted post for Mis information
Faztbullet
Never use silicon to seal crankcase half's as it will fail !!!!
Loctite master basket 514 (OEM# 92-12654-2) and use the primer also
Nuaticocat
Thanks for the info. I have searched that number and come up with zilch. Where can i get it? Any particular supplier you like?
