Probably one of the most often asked questions. Ranks right up there with "Motor won't crank".
Any water that comes out there has gone through the engine and done its job and is on it's way back to the sea anyway. Don't give it a second thought. In fact, if you look closely you will see a drain hole (or holes) that deliberately drain the same area.
