Gasket sealant.
James R
I used to use OMC sealant until it got too expensive then I switched to Perfect Seal. I see now that Perfect Seal is not available. Can you tell me the replacement?
Thanks.
Lou C
I've used both, they are not exactly the same but close enough.
James R
Most grateful for your input. Tried Napa but they can't get it or the Loctite product which is supposed to be similar.
I'll find some.
Thanks again.
Lou C
Permatex Aviation is usually easy to find. I just bought the big size of the Evinrude Gasket Sealer from Amazon, it will probably last me at least 5 years.
Be careful with gasket sealer on outboards.-----I have seen a EWE TOOBER smear lots on gaskets.-----I am sure he did not realize he was possibly blocking oil recirc channels !!
Lou C
good point. it works great on bolt threads to prevent seizing in salt water use. I use it on thermostat bolts and gaskets, etc.
