Are the two o-rings in
this gasket set for the plastic water housing which mounts in the pivot assembly or for the driveshaft?
The title is misleading in that is says "outdrive gasket" but the other oddly shaped gasket is really to seal the water housing mount area in the pivot assembly.
Thanks!
