Gauge fitting bracket
Tafflad
I am fitting a new gauge .. nominally 5" diameter, panel hole will be 4 5/8" panel cut-out ... fixing studs 3 3/4" centers.
It needs to have a mounting ring/clamp/clip to fit it.
Picture of one for a 4" gauge attached. (black plastic fitting clip)
Anybody know the correct name for these, and where I can obtain one to suit this 5"
guage. Manufacturer of teh guage do not supply them and advise I have to source.
Click image for larger version  Name:	Plastic basket-clip.jpg Views:	1 Size:	78.1 KB ID:	10812994
alldodge
I think your talking about a Bezel trim ring
Edit: ok GA has it
GA_Boater
Hi Tafflad.
What you could do is make a mounting clamp similar to #4 as in the drawing below. Many gauges are mounted like this. A strip of aluminum would work.
that mounting bracket comes with the gauges from the factory. as GA stated, you can make it out of a small strip of aluminum or stainless.
