gauge replacement?
lingcod
I have a 1984 115 yamaha ETLN and I want to replace the gauges with something a little nicer looking. I want tach,trim fuel and volt gauges. I have to keep the low oil gauge as I think it is yamaha specific. can I order new ones from teleflex for all these or do I have to go thru yamaha at an outrageous price? yamaha $304.80, teleflex $130.96.thanks in advance
lingcod
Silvertip
Re: gauge replacement?
Voltmeter and fuel gauges are not engine specific. Any brand/style will work as long as the fuel sender in the tank and the gauge match. Sender is typically 33-240 ohms. Tachometers are fairly universal and can be adjusted for the number of alternator pulses it sees from the engine. A 12 pole alternator produces 6 pulses to the tach. Don't know about the trim gauge. It too must match the Yamaha sender and as such may not be "generic"
lingcod
as far as the tach goes, I am seeing either a 6000rpm or a 7000 rpm tach. my WOT is about 5200rpms. Which tach is for me? current model is a 7000rpm.
lingcod
