iamslotman
- Jul 31, 2010
- 24
hello.... I have a 94 Four Winns Sundowner 195 with an Evinrude 150 outboard. All the gauges are mounted on a printed circuit board similar to a cars dash and they are all acting up. I am hoping someone can direct me to a wiring diagram so I can either find a loose connection or rewire a new dash with individually wired gauges. This dash has fuel (only goes to 1/2 way even with sending unit wire grounded) tilt/trim (jumps) temp (jumps to full hot immediately) tach (jumps all over) speed (zilch). Last summer the temp, tilt, and tach worked but now they are all on vacation. I had the alarm tested for overheat and it works so I am relying on that but I really need some gauges. thanks
