Gauges for kicker motor?
tsbrewers
Hey all, I just added a used Yamaha T8 kicker to my boat and I am wondering if I should be hooking up a gauge or two to the kicker motor? The main motor is a Yamaha F60 which is hooked up the gauges on the console, so I am wondering if I can just tie in to the same set of console gauges? or if I should add a multi gauge for the kicker itself, or not worry about at all?
Thanks,
your yamaha 60 has sensors, and everything to make adding gauges easy.
your kicker doesnt have provisions to add sensors
the only gauge you can add easily is an inductive tach.
you would have to have separate gauges
however as a kicker, your not worried about high speed. you simply want it idling along slowly. the only thing the tach would come in handy for is the hour meter for service. yet 99% of the motors hit the calendar trigger for maintenance and not an hour limit
so what is the point?
alldodge
Temp gauge might be the one I think of, if it has a place to install one
I believe that the low oil/high temp warning light system takes up any potential locations for a gauge temp sender
tsbrewers
Thanks, I wasn't too concerned about them, but I didn't know if I should do some kind of temp/oil/etc. gauge in case of issues. It is a remote setup and not a tiller, so it might have more sensors available than a tiller model. (I don't know, that is a guess) I have the full compliment of wires coming from the control.
look at the manual.
should have ignition/start/batt/ground/choke/idiot warning coming thru the wire bundle
tsbrewers
Thanks, no manual, but I will see what I can find online. the idiot lights realistically would be my biggest concern.
I think its a combo light comes on for either high temp or low oil
Sea Rider
Just install an induction hour-tach for the portable and check that's running full wot revs factory stated as loaded. Will surely need to install a less prop pitch from current one for that purpose for OB to push combo much better than if doing nothing.
Can install the tach at front cowl...
Happy Boating
