Gauges for Outboard
joey nathan
'75 3-cylinder 70HP Evinrude
How do I go about getting the correct tachometer for this engine? Is it a matter of how many "poles" in the stator? Or will any tach set up for a 3 cylinder work for me?
How do I determine number of poles?
Has anyone instrumented an outboard with the full package of gauges, i.e., oil pressure, water temperature/pressure, voltmeter, etc.?
Restoration coming along, I'll be cutting and fitting new floor of 1/2" marine plywood and fiberglass today.
Thanks all have a great daY!
Numlaar
Re: Gauges for Outboard
Most tachometers are "universal" meaning they will work for a lot of different motors, and have a dial setting on the back to set it for your particular engine.
That motor uses a "6P" Setting, and should have a gray lead coming out of the controls for the tach.
You can instrument most of the items you mentioned, however, a 2-stroke outboard will not have an oil pressure gauge.
Hope that helps!
Chris1956
Stick with water pressure, tacho, fuel and voltmeter for an outboard. Water pressure is more important than temp.
