Gauges
tblack111
I have the normal dial type gauges on my 08 bass tracker. The speedo has not worked for over a year, and not my tach is bouncing back and forth like a ball, not giving me a true reading of my RPMS. Any ideas for possible repair? Or is it time to replace them both? Fuel gauge still works.
IF replacement is recommended, is it a simple swap out? Where is the best place to purchase?
Re: Gauges
Ayuh,... The tach is wired to the motor, look for a loose or bad connection...
The speedo is probably driven by a pitot tube mounted on the stern...
Look for problems with the pitot tube, or it's tubing to the speedo...
