Gear case cover
bluebackfisher
I have 1992 Force 150 hp motor that I purchased a couple of years ago and upon servicing the water pump, I noticed that the gear case cover under the water pump looked like it was in need of replacing. I am not having any luck finding a new or even a used one. If anyone here could help me find a new or used cover I would greatly appreciate it!
Use ---google-----To see if anything shows up.----There may be some on the shelf somewhere.
bluebackfisher
Thank you so much for your replies. I’ll post some pictures. There’s a chip and a couple of cracks in it. Maybe it’s not that bad or could I repair it with JB weld? I also am including a couple of pictures of the top of the water pump showing a couple of cracks. Does that need to be replaced as well? Any advice you can give me will be much appreciated!
jerryjerry05
If it's not leaking oil, Not sure I'd do anything, same with the pump, the important parts are the impeller, the impellers cup and wear plate, again
not sure I'd do anything??
JB Weld or sillycone.
bluebackfisher
Thanks again, I think I’ll pressure test the gear case this weekend to be sure that it’s not leaking.
jerryjerry05
What color was the oil when you drained it?
If it's brown it might have water mixed in??
