tommythecat
- Jul 21, 2018
- 27
i was told i should start a new topic for this new problem so here goes. i changed the water pump and the gear oil in the lower unit and took it out for a test ride. it all seemed to work but when i checked the gear oil it turned white. i didn't go far and it was working well as i took it out so no damage im pretty sure of that. i don't know where the water got in but there was a bit of oil came out the weep hole right by the shift shaft so i was assuming maybe the shift shaft bushing? but how do i know and where all can it be getting water in?
so i also could use a hand finding this gear seal kit my boat motor model number is 857HE i think it is 1973 and it is a chrysler 85hp outboard if anyone can help i thank you in advance.
