Gear Change in Cobra SX drive
Jammer864
1995 Cobra SX drive with 5.8 EFI in a 23 ft Four Winns Horizon.
I have an opportunity to buy a never used Cobra SX drive with 1.43 gear ratio. My current drive is a 1.51 ratio. Would using a smaller pitch prop make up for the gear ratio difference?
Re: Gear Change in Cobra SX drive
Ayuh,... Generally speakin',... Props are only available from about 15" pitch to 23" pitch...
Soooo,... It'll depend on where yer starting from...
Jammer864
I am using a 21 inch prop right now at sea level. When I was in Colorado and Utah, I used a 19 with good results. On the face of it, Im thinking I should be able to go down another pitch or two with good results using the new gearing, but am needing another perspective on it.
