Re: Gear Lube level
You have it right, unless you have one of the newer legs with a small oil bottle inside the boat. On the older style legs the oil should come up to the vent hole on top. If it's almost full you can top it up from the top with a syringe. Its also good to crack the lower hole and let a little oil drain out to check for water (the oil gets milky).
