While out on the lake yesterday our 5.0 alpha 1 Gen 2 started making a noise under light load. When we opened the engine compartment lube had been sprayed onto the port side of the engine compartment. Have had no issues with this boat before. Changed impeller and lube at beginning of season. Been out every weekend without issues.
Drained outdrive and lube was clear ( not milky). Did have a few metal shavings on drain plug.
90 degree fitting from lube monitor is intact.
Any suggestions?
Any suggestions?
