Re: Gear Lube
I doubt it. They're all high viscosity gear oils, with tremendous film strength. The High performance has higher film strength, and an acceptably high film strength even with a little water in it.
My XR4 gearcase is on the edge of extinction right out of the crate because of the large amount of power going through a small gearcase. That's why my mechanic had me change the oil.
The shifting in all of them is slam bang dog clutch stuff, so "friction modification" additives you could need in a synchronized transmission are out of the question.
Merc Hi-performance gear lube is expensive, but worth it.
Use it.
hope it helps
John
