Gear oil in bellows
FreeBeeTony
I recently replaced the seal on the yoke. I only used the boat once since then to check out the rest of my rebuild of the lower unit. I removed the drive today to winterize and found new gear oil in the bellows! Is it possible I put the seal on backwards? I replaced the seal and the carrier. Or is it probably the yoke being worn?
Skinsk
Re: Gear oil in bellows
If the seal surface of the yoke had any grooves, or rust, it is probably leaking.. <br /><br />Seal should be installed with lips facing in towards the gears...<br /><br />did you also install a new O ring around the seal carrier?<br /><br />Scott..
