1983 50hp Evinrude E50BELCTA
So I noticed a couple of drips of gear oil coming off my skeg the other day. It turns out is was coming from the prop housing, so I took off the prop and found a small pool of gear oil in there. The outer shaft seal is dry, so it must be coming from an inner seal....Here is a pic...
That small pool was after a couple of days. It doesn't leak when the engine is tilted up. What part am I looking for to fix this? Is it 27 in the pic below (0320303 | O RING BRG HSG)? Also, do I have to drop the whole unit to replace it or can I remove the three bolts in there and pull it all out to replace it?
http://www.crowleymarine.com/johnson-evinrude/parts/44375.cfm
Thanks for any help!
