Gear oil leak
Rob Laz
Boat: 2010 SeaRay I/O 17 1/2 feet
Engine: Mercruiser 3.0 Alpha 1 Gen 2
I noticed that gear oil was leaking out of water vents on the lower half so when I removed the lower half and in process of changing the impeller, I noticed that the oil seal carrier, carrier compartment, impeller and impeller housing all had gear oil (for some reason I cannot upload pics). Before I change the impeller and do a pressure test, could this be a leak somewhere near the oil seal carrier or the carrier itself?
Rob
Rob Laz
I will look there. Should there be lube oil in that carrier assembly compartment and impeller housing?
alldodge
No and those parts mentioned previously is what keeps the water and lube separated
