gear oil leaking
randy becraft
Hi everyone. Was changing out impeller and shiftshaft bushing/seals,and gear oil on lower unit .While refilling oil I noticed oil running out prop shaft area where exhaust exits. How hard is this to fix?Was it because of something I was changing, or did a seal in lower gear case let go? This is on a 93 alpha1 gen2 unit.Just got it all back on boat after replacing the bellow's and shift cable.Any advise would be appreciated.Thanks Randy dripping oil in North Carolina
Bt Doctur
Re: gear oil leaking
missing quad seal,(smallish O ring between the units), upper shaft seals bad
If it didnt leak before you worked on it, recheck your work.
randy becraft
Thanks, pulled lower back off and no o-ring.Also I did notice some oil running down from upper shaft, but that may had come from pulling the lower unit down and off...Just an o-ring up in there and it looked good....It's one of those sterndrive engineering clone's(upper drive) that is almost brand new and o-ring seems good.Also noticed that where "quad ring" sets,upper unit recess is slightly smaller than lower unit recess.Thinking o-ring sets inside of smaller recess maybe held in place with some bellows glue or some great seal...You'r thought's please, and again thank you.
Bt Doctur
contact cement, bellows adhesive, etc to hold it in place.GEN ii`s will leak with the lower unit removed unlike Alpha`s that wont if the seals are good.
