Re: Gear Problems on 1964 Johnson 90 hp
You better hope you got a spun hub ,the other alternative is far more expensive
<br /><br />When did you check the oil in the lower unit , the 1964 90hp got a electric gear . <br />Check the oil ,if you find water in it ,change it , use ONLY oil that's made for OMC electric LU's ( Named "Type C " or OMC premium blend )<br /><br />One other thing to check is the charging + battery , to function good this LU requires a good battery with max power . <br /><br />If it's still not working , it's going to cost you some BIG money .<br /><br />For more info about this LU , try a search on electric gear ,electric lower unit , NOT hydroelectric.
