gear ratio
codyandamber
How do I find out what gear ratio I have? It is on a 79 pre alpha with a 305. Also where can I find the prop slip? It is on the prop, right? Thanks,
Re: gear ratio
You have a V8, So you Should have a 1.50/1 Ratio.......<br />Your Prop Should have the #s on the End of the hub, under the nut + lockwasher, Or stamped into the side of the prop, at the base of the blades....
codyandamber
Re: gear ratio
which of these nubers tell me the prop slip <br />48-88440A-19???<br />It is a 14.25" x 19p<br /><br />thanks
Re: gear ratio
Prop Slip is calulated with the Actual boat speed, Vs, The Calulated boat speed....<br />Your Prop Pitch is 19"......<br /><br />48-88440A- ... is the Part#s
akriverrat
Re: gear ratio
19" times rpm, divided 12", times 60 minutes, divided 5280' = mph. differenc between this and measured mph is slippage.
