Gear ratio
Ray74
I have a 1998 Johnson ocean pro 130. Model number E130TXACB. Anyone know the gear ratio?
Could be 12:27 or .44 on that motor.------But there are different lower units that will fit as well..----Remove sparkplugs.----Put motor in gear.------Turn flywheel 10 turns after prop starts turning.-----Count turns of the prop for 10 turns of flywheel.
Ray74
I know it has the v6 gear case. Im thinking its either 1.86 or 2.25 just not sure which one
