Gear ration of a 1981 merc outdrive
Cast-A-Way
Good evening everyone.
I was just wondering if anyone can tell me if the gear ratio on a 1981 merc 225 hp would be ok to couple up to a 1973 188hp.
My outdrive is shot and I am looking for a donor boat
Cast-A-Way
This is the outdrive I am looking at
Ayuh,..... They both should be 1.50:1 gear ratio,.....
Cast-A-Way
Thank you. Anything special I should look for other than cracks and oil in lower unit.
I will also need the gimbal housing. I will check the pins for movemenr
Cast-A-Way
Also is it safe to assume that the 225hp that I am looking at is a bigger v8 than the 188 I currently have...I know it may be a silly question but I may consider doing a full swap
Ayuh,..... I'm Guessin' the 225 hp is a 305 Chevy, with a 4bbl. carb,.....
Or, possibly,.....
A 350 Chevy with a 2bbl. carb,.....
I suppose it could be a 302 Ford like yer's, with a 4bbl. carb,.....
I think the 235 hp was a 351 Ford, 2bbl carb,....
With "Used" stuff, you inspect Everything possible,..... even an oil sample if ya can,....
