I am replacing the Gearcase Housing Assembly 396199:due to broken skeg and small (freeze?) crack on motor I bought recently. Motor was missing Rear Thrust Washer 324689. What gaskets/o-rings/ seals would I be well-advised to replace (in order of most important to least important)? Ex: Shift Rod O-ring 305242.... I will probably replace Impeller too, although it looks fine. Thanks in advance for input..
