IS it hard to replace single or double seal .and should i go deeper to sotp the leak? When i changed the gear oil it was gray . so it had water in it so i drained it and put new in . I removed the propeller to see if it had fishing line wrapped in it there was nothing. So out came the book. The motor is a 120 hp v4 1994. I all so ran the motor for about ten mins it was leaking .slowly
