Re: gearcase size
The 15" motor uses the props from 11 3/4 to 12 1/4" diameter, generally speaking. The gearcase diameter is about 3 1/2". This is the motor used in Sprint and Formula E racing but can be used on a recreational boat too.
The 20" motor uses the props that are generally in the 13 1/4" diameter. These are the same type props for the V4 motors. The gearcase is about 4 1/4" in diameter.
Look at the numbers on your existing prop. You'll need that for the pitch range anyway.
