Gearcase was in Neutral and Shifter Was In Reverse When Installed? Yamaha F40 2000 ES
Bswelch2
Ok so first off I know I did it wrong and need to drop the lower unit and redo. What happened was I dropped the lower unit to replace the water pump and put it in neutral. Then read that to reinstall I would need to place in reverse which i did not thinking that the gearcase which was now removed in reverse also. It idles high and I put it into gear for a few seconds and grinding was heard. I am worried I have ruined the lower unit please tell me if I have. If I have not would simply dropping the lower unit and putting them both back into sync fix this. Any help will be greatly appreciated, I know I am an idiot and should have read through the seloc multiple times!!!!!!!!!!!!!!!:eek::eek:
rodbolt
Re: Gearcase was in Neutral and Shifter Was In Reverse When Installed? Please Help
wow
is this a mazda or a cessna or a backhoe?
Bswelch2
Lol sorry I am a new poster. It is a Yamaha F40 Electric Start 40 Hp 4 stroke model year is 2000 manual trim and tilt.
Branden
