gearing effects
BLC
I just replaced the upper gear set in my 1989 1750 bayliner capri with a 2.3L omc cobra. It had 21/21 upper gears. The marine supplier that I ordered them from said that they no longer make the 21/21 set anymore and said that they are installing 21/19 tooth sets instead for this set up. So thats what I installed. This boat is new to me so I don't know how it ran before with the 21/21 set. How will this effect the speed and torque preformance of the boat
I don't know if this matters but the prop is 13 1/4 x 17.
Thanks
hwsiii
Re: gearing effects
WE need the lower gear set as well.
H
BLC
Re: gearing effects
Now, I am assuming that the lower gears are still stock. If so they would be 13:26 according to the manual
hwsiii
Re: gearing effects
Your new gear ratio is 1.81:1 instead of the 2:1 you had before the gear change. You lost about 10% of your torque output and gained about 250 RPM top end if the motor has enough torque left.
H
BLC
Re: gearing effects
So the bottom line is that I will have less torque but more top end speed? Will the top end rpm be 250 higher or am I misunderstanding something?
hwsiii
Re: gearing effects
Theoretically, you gain 250 RPM but you lose extra torque, so usually what happens it is a wash and you keep about the same speed maybe an extra MPH and your RPM will rise a little.
H
QC
Re: gearing effects
Classic explanation of HP = torque x RPM / 5252 in this discussion . . . Theoretically HP stays the same here. Oh, and propshaft RPM will rise for the same engine RPM, but your engine RPM will actually drop for the same boat speed ;) Lower numerical ratio is a higher gear.
Re: gearing effects
Ayuh,... Bottom line is, it'll probably be a Dog because that little bitty motor won't be able to pull the taller gears...
