Outboard is a 1968 3hp Evinrude
Can't seem to find the infinitive answer of the proper lower gear lube to use. Also there are two screws in bottom casing one above the other, one reads oil level the other drain. So do I drain from the bottom one and fill from the top? I"ve read somewhere some said fill from the bottom until it come out of the top the place bottom screw in, this procedure doesn't make sense.
