Went out on the lake the other week noticed we was getting some jerks. Felt almost like a transmission skip as a car would have. As we was going the 2.3L OMC started giving this jerk feeling every couple of seconds. as if a gear was slipping. Then the motor just had one more slip and she cut off. Everytime I tried start her from then on the steering wheel would just jerk, and you would hear a click as if something jammed inside the motor, or a gear, and wont let it do anything.
So basically where do I need to start? Seems like when I go to start the motor it wants to turn over, even jerks the motor. But seem like something just isn't leeting something turn. Can't seem to Get past that Click, and the sound of the engine when it jerks. That will only last a half of second, whatever is jerking its also turning my steering wheel, as well as my outboard part of my motor. All I can think of a gear broke or something and has it locked the motor? Any ideas where I should check first? I feel it may be in the upper or lower gear housing of the outboard unit.
