I recently did some gelcoat repair inside my boat using the Everglass white gelcoat. As per the instructions, I mixed the hardner, put it on, and let it sit a short while, then sprayed the PVA Mold Release on top to ensure total cure. Came out great, but would like more coats to ensure smooth covering. My question is; if I am going to put on multiple layers of gel coat, do I need the PVA after each coat, or just put on the subsequent layers on top of the "tacky" gel coat, then use the PVA for the final coat? Thanks
