Re: Gel coat repair needed in Tampa,Fl
It's above the water line on a 2011 sea ray, black hull. Ill start reading up on the DIY thing. Being that it's new though makes me reeeeal nervous tho.
Blending that black is a biatch ..
Spectrum Gel is Jet Black = NCP -1465A
Those black hulls are hard to blend in when spraying ( perosity galore ).
If you come to a point where the blend spot is not matching.. Pressure wash the patch to get rid of the blend lines. Actually tell the guys to Buff with a Dark compound instead of the White Compound. .. it can make ther job a bit better on the match.
I have had to add Black pigment to the Factory gel just to make it blacker to match ( they at SR know this )..
Any more questions just ask.
YD.
