Bomber Goober
- Dec 28, 2012
- 183
I decided to make a new thread for this because after much searching I cannot find the answer I'm looking for
I'm preparing to do a full respray on my hull this upcoming weekend. I would like to have a blue stripe down the side the same as in the picture, except not in glitter.
Do I do the blue first and then mask off and spray white? Or white then blue?
I am also concerned about the hard line that will be formed by masking off the top of edge of stripe. The bottom wont be an issue because it will be hidden. Would it be better to use the soft edge foam tape and then use a vinyl pinstripe to hide the "seam"? Or is their a simpler method to accomplish this?
As always thank you for any input you may have.
