gel-coat resto
Bob_VT
Re: gel-coat resto
Search iboats for vertglas We have seen very mixed results
Woodonglass
Re: gel-coat resto
I answered this for another iBoater just yesterday,
Welcome to iBoats!
Ok, Here's what another iBoater says he did....
Went to an automotive paint supply:
3M -Foam polishing pads w/Velcro backing + mounting pad
3M Super Duty rubbing compound 1 Qt.
3M Finesse It Polishing compound 1 Qt.
order online Collinite Marine wax (ebay)
1 - variable speed grinder/polisher - Heavy Duty - Harbor Freight has em for $40.00
Wash boat real good using a solution of simply green + dish soap..rinse well...dry.
In a shady area apply compound to a 4x4 area with buffer..not too much pressure,let the machine do the work..slow speed. work around boat till all hull & topside are done.
Switch pads OFTEN or thoroughly clean existing,buff off all compound,again, let the machine do the work,work left to right up & down until you archive a good shine...black is a bit#h so stay off it until everything else is done....Ok so now its shiny and covered with compound dust..wash boat again, Repeat above steps with the Finesse It.....wash again....run a clean rag over entire boat making sure ALL compound & polish has been removed...If so then wax with 2 coats of Collinite...and i promise it will look brand new. You will hear alot about these Modern Marvels and Magic elixirs...NOT WORTH IT. The only way to achieve a deep..lasting shine is the above method, ALOT of work ,but worth it.post some before and after pics.
As Bob stated, this topic has been discussed in much detail on here and the Red Text says it best.
