dlogvine
Master Chief Petty Officer
- May 4, 2015
- 839
Today I tried to spray gelcoat first time (in my life). So first of all I made sure my cleaning liquid was at hand and ready for use. Next I made sure I can measure resin hardener ratio correctly. Felt like counting drops was a really crappy idea, I decided to do it mathematically correct using percentages. To do this I got a measuring syringe, they are free at any pharmacy. Next i found a conversion rate from ounces into mL, 29.5 mL in one fl.oz. Then I measured 2oz of resine and multiplied this by 29.5 and then by 0.015, got 15%. Same way calculated 10% for styrene gelcoat thinner and mixed it all. Couple problems I encountered. I did not shake the resine well, so got a top layer from the container that had no colorant, so I got a clear spray. Will see if it will turn white when it hardens. Second problem is at the time and temperature. I started spraying later in the evening when temperature dropped to little over 60, from about 75 earlier in. Will see how it hardens over night.
Now I have a couple questions, gelcoat I purchased contains wax. Should i use it or get the one without? Second, if the label said white gelcoat, it means it should be white when applied or does it turn white when hardens? And if it should be white when sprayed, do I just shake the container to mix it up? Do I need to use the mesh filter in the gun or it wont let the gelcoat pass through? I removed it and looked like I had a good spray. Last question, I shouldn't be overly concerned with overspray, since I'm going to sand it later?
