Hi
Bought a glastron sierra 199 last spring,engined turned out to be cracked.The boat didnt see any water this summer because of a repower.Im almost finished with the engine,just some slight tuning left.The complete interior is being redone.
Heres a couple of pic of the boat when I bought it
The boat is 20 years old,its suffers from stupid owners syndrome,lack of maintenance that is.I have fixed and removed a whole lot of bad wiring,cheap repairs,stupid stickers etc.The transom,stringers and floor seems pretty solid(knock on wood).
The boat has quite a bit of gelcoat cracks that I would like to fix.
1.The gelcoat under the windshield was painted black(because of reflection?),seems that the heat caused the gelcoat to crack like a spiderweb.See picture
2.Cracks at some parts were you can tie a rope to.This is because the boat has been moored at the wrong places(again stupid owners syndrome).See picture
3.On the left side on the boat just above the waterline there is a area that is aprox 4 f long and 1 high that has spiderweb cracks.It looks like it have been pounding against the pier because of improper mooring.Its not misformed or anything,just spiderweb cracks in the gelcoat.
I seldom take any shortcuts,I hate to do something over because I cheaped out the first time.But im a student which leaves me with limited time/money.I have done some minor fiberglass work,but never used gelcoat/topcoat.
1.I was thinking about sanding some of the gelcoat down,leave it rough,paint a couple of layers of topcoat with a brush,and then sand and polish the surface.
2.I was thinking about grinding the cracks open like a V,and fill them with gelcoat,and then sand and polish it up.
3.Im not sure what to do,its a critical area since its close to water.The cracks are very close to each other,so I dont think grinding out the cracks will work.Also the fiberglass could be compromised and might need reinforcement.I could grind the whole gelcoat to the fiberglass,but how would I get the surface back and even?
Any suggestions,what will work and what not.Otherwise the boat will need a good polish and wax and shes good to go!
