Had an accident the other day while on the water. Ran up on a sub surface rubble pile. Damage wasn't too bad. Three seperate small dime size gelcoat chips to the bottom of the boat. I still had some gel coat repair kit leftover, so I sanded the scratched/damaged area down. Wiped clean with acetone. A few hours later I'm getting ready to apply gelcoat, and I noticed drops of water coming from a couple of the areas where the fiberglass was exposed from the chipped gelcoat. I wonder if the acetone has anything to do with drawing water out or some sort of chemical reaction, because I didn't see any water before I sanded and cleaned the area. Is there any way to dry up this water? I don't understand where it could be coming from, because the boat is brand new, and there is no space between the gelcoat and fiberglass in the damaged area. Thanks for any help!
