I have a small gouge (2 inches long by 1/8 inch wide and several scrapes from a<br />miscue (boat drifted into a elevated prop) The ammount of gelcoat needed is less than the ammount indicted on the mixing instructions. I would need less than a teaspoon worth. How much MK?? (catalyst) do I need to use as they claim if I use too much the stuff won't cure. Any tips on colorization? Can I do this in 40 degree temps? I've always sanded relatively<br />deep scratches and scuffs with 200 to 600 grit paper with excellent results. Would love to hear from all of you gelcoat gurus.
