Gen 1 or Gen 2 How do you tell
Taz59
Alpha One Gen 1 or Gen 2 how can you tell whats the differance.can't attach picture ??
Cheers
Col
Re: Gen 1 or Gen 2 How do you tell
Ayuh,... The Gen.IIs have the upper unit to lower unit bolts/ nuts Exposed,...
They're somewhat hidden on the 1st gen. units...
Taz59
Found a serial number on the Alpha one its OF57694 can i found out by this number
Col
Don S
It's a Gen II drive SN, even if you didn't have all the SN. It should have 6 numbers following the F.
PitchFork
I have also found that the place where the Gen II trim cyclinders hook on to the upper housing are much wider than Gen I.
TilliamWe
Banned
Cheers
Col
Shape and angle if the skeg is the easiest way. The Gen 2s skeg is larger and angles back towards the prop at the trailer edge. A Gen 1s skeg is smaller and is at a 90 degree angle to the gearcase at its trailing edge.
z284u2try
I was under the impression that gen 1 had the trim cyl on the lower case. and gen II had the cyl's on the upper part of the case.
