Gen Ed Electrical ?
Badtracker
Have a general electrical question. Just installed a electric anchor winch on my pontoon. Is it best to use the winch with the motor off? I have dual batteries with one battery just for the winch/accessories...I've heard that big power acessories can pull more amps than the regulator/stator can put out and it may burn something up? Not sure if ithis is possible since the stator just charges the battery...don't see how running the winch can feed back into the engine's electrical system.
BTW -Engine is a 50HP Merc 2 stroke.
MarkySparky
Re: Gen Ed Electrical ?
I would run it with engine running- less voltage drop that way and winch will be a lot happier and batteries will live longer too.
Fireman431
With the engine running. The engine only puts out a specified amount and that is regulated to the battery. With the engine off, batteries die quickly with a windlass.
Neted
Definitely with engine running.
Sent from my iPad using Tapatalk
Fireman431
Besides, you NEVER pull the anchor until the engine is running anyway!
Fireman431
Absolutely. It's the boat (and motor) breaking the anchor loose, not the windlass...
True, but I was leaning more towards the thought that you would be drifting without means of propulsion and/or steerage.
jhebert
Ensign
I served under General Edward Electrical. He was an outstanding leader and commanding officer.
109jb
A 50 hp merc has a permanant magnets in the flywheel and a stator which make a permanent magnet alternator. Not a field excited alternator like a car has or an I/O boat has. The strength of the magnetic field is fixed. At a given rpm it can only put out a given amount of current. You can't overtax the stator because it just doesn't care what you are running. It is always putting out that amount of current. Any excess current is wasted as heat by the voltage regulator. That's why the regulator has the heat sink and fins on it. It starts putting out its current as soon as the magnet ring is turning any rpm, the current it puts out just goes up with rpm. If this weren't true then none of the non-electric start outboards would run at idle but they do. Actually, the thing that is taxed in this type of system is the regulator when there is high rpm and little load because there is a lot of energy (heat) to get rid of. The regulator is less taxed when there is a lot of load.
On a field excited alternator, like a car has, the regulator adjusts the current going to the field coil which adjusts the strength of the magnetic field. More magnetic field equals more current output. The problem is that as load goes up, the regulator keeps increasing the current going to the field coils and if the load goes high enough you can get to a point where one of 2 things happens. 1. Either the current going to the field coil is too high for its windings to takeand it burns up, or 2. The current generated in the stator is too high for its windings and it burns up. That's how you an burn up this type of alternator..
As far as the OP's question, no you can't hurt anything by running the engine while running the anchor winch.
