I recently had some work done on my motor, a Mariner 75 hp, pro series, 1996, 3 cylinder (has oil reservoir separate from the fuel tank). The motor sits on a Bass Tracker Magna 17, "V" bottom boat. Took it down to the Independence, Missouri Bass Pro-shop because of motor problems and not knowing who to take it too. Well, they couldn't figure out that the "trigger" was bad, replacing fuel pumps, switch box, regulators etc. Finally, found out about a place in Boonville, Missouri (a small town) that has much smarter/honest persons working there, that fixed my motor. (Big thank you to them!) Anyhow, they mentioned that there are some vibrations coming from the prop; that it should be repaired or replaced, sometime in the future. The writing on the propeller states: SOLAS MYTH and D 3X13x21R. I think it's OEM. Looking at the links here, at iboats, plus, not being familiar about this stuff, I want to see if I'm correct: It means 3 blade, 13" diameter, 21 inch pitch with a right hand/normal rotation. But I see others talking about slippage. What's that? It's just an ole fishing boat. . . Looking for a new prop. I saw a Solas Amita number 1411-130-21. Is that the correct one and is there anything that should also be replaced at prop changing time? Thank you,
