Thanks for all the input, I really appreciate it; How do I check the prop shaft with prop off to make sure it is straight?? Also, some more general ???'s; prop turns by hand, with a slight wobble to it; took prop off, the shat itself is harder to turn w/out the prop on it, is this normal ? Also, there is a small chunk of metal missing from this part, not sure what it is called, I think it is the prop shaft housing; Is this a big deal ? Any quick fixes ? <br />
